Biggwaukegan
Banned
Guys.....Im gonna replace my timing chain tomorrow along with a new oil pump. Is it better to get a good timing chain or even a double roller or should I get a quiet Timing Gear Set and be done with it? All input is welcomed
How did the replacement go? Not to jack your thread but I don't think my timing chain has ever been replaced, I'm at 144,*** should I do it soon?
Don't know if there is a replacement interval recommendation at all. Unlike many imports which use timing belts, the timing gear/chain are metal and don't stretch as easily as belts do... I've got ~250k on my factory original.Damn 242k... Does anyone know when GM recommends timing chain replacement?
Guys!!!!!! come to find out the only timing gear that will fit the Beast is dam near $400. Reason being is because of the fact our crankshaft position sensor plugs in there. Shit So I guess Im gonna go with a single roller...Most likely Edlebrock or Cloyes. Well hope that helps someone down the road. Thanks for all the input fellas
