Tire pressure for bigger wheels
dmurph112
First post, been reading these forums for a few months now. Have a 17’ suburban with a 4” ready lift, just installed 20x9 +01 offset Ultra Nemesis wheels with LT285/60r20 Continental TerrainContact A/T tires with max tire press of 80 psi. (Slight rubbing, will do NorCal mod later). Stock tire pressure is 35 Psi. I emailed Continental with the new wheels specs and they said 41 psi. The new tires are basically 33.5”x11.50”. The shop that mounted the tires said they runs LT tires around 50-55 psi. Just looking to see what some of you guys run your tires at. Thanks, it’s great to read all the informative posts in these forum's
Matt_
I always go by the TRA load vs inflation tables. Can use the GAWR or the stock size/pressure to convert to required pressure for different sizes. An LT285/60/20 at 41 PSI has a minimum load rating of 2,220 lb, which would allow for 4,440 lb on each axle.
When I upgraded my tires to Michelin Defenders (305/50x20 versus 275/55x20), I contacted Michelin to find out what their pressure recommendation was. They told me that since I had not changed the load class of the tire, but simply went to a larger tire, that I should still use the recommended tire pressure for the stock tire.
Tonyv__
Bucks county PA
If you guys are increasing tire pressure. How does your tpms recognize if a tire has low pressure? Is there a preset in the system or does it compare to the other 3 tires then alert you.
Matt_
It's a pre-set. Going from a P-metric to an LT tire usually only requires a slight increase in tire pressure and is normally a non-issue. No reason someone should run 60+ PSI in an LT tire on a vehicle designed around 35 PSI in a P rated tire.
It's actually the other direction where most run into TPMS issues, my 2500 runninig 35s is an example. Going to a larger/wider tire in the same load rating generally requires less pressure to match the load rating. For slight tire size increases its not a big deal and you just keep the pressure the same, but my 35s run at the recommended pressure of the small/thin stock size turns them into harsh bricks. The "proper" pressure for my oversized tires is close to the TPMS low pressure alert... i'll get that alert on cold mornings, but luckily i have a display with actual pressures and can see if a tire is indeed "low".
You said bigger wheels but I guess you meant bigger tires? 24-26” wheels also need a bit more pressure in my experience since there’s not nearly the tire cushion but you need to experiment- it’s a trade off in ride quality which I imagine goes with the bigger wheels as well.
STORMIN08
personally, i have always adjusted to the PSI that offers the best ride without inducing odd wear patterns.
my heavy 3/4T trucks on 37's run 40 F/32 R, my suburban on 22's with a 33" runs 37 all around.
dmurph112
dmurph112
I originally had stock p265/65R18. So I went up in wheels and tires.
Here is the response I received from Continental
With the stock tires I would also air down to 18psi to drive on the beach. Any recommendations for a new psi to air down to now.
Matt_
Thats the same process i've used for going from P to LT. I dont know why more shops don't train their techs to use the load vs inflation tables... its really not that hard.
You have about the same sidewall height and an inch more tread width to start, so ~20 psi should still be good for the beach. Can try 25 and see if you still need to go lower.
retiredsparky
Another option is to find a flat, open parking lot area. Draw chalk lines across the tread and drive straight ahead far enough to get a few tire rotations and observe the pattern of wear shown by the location of chalk removal.
jjmasterson
