Tire Question?
Juiceman74
So I am planning on putting 20" rims on my truck and i was wondering how big of tires i could get on my truck if i only put a 1.5 to 2 inch lift on the truck?
M3kanic
Depends on the offset you want to run. I have 20x9 -10 with 275/60 and I have rubbing.
massivespl
I'm not mean, I'm honest.
Michigan
My buddy has lvl kit and have 285/65/20 on his truck no rub with a offset in the 30s
I've had lots of 275/60/20 on stock 20" rims with no rub at all.
M3kanic
He probably went with the stock offset which is in the +30 range. I went with a -10 so my tires were flush with the outside of my suburban.
Juiceman74
Juiceman74
I am new and I don't really know what an offset is, can you explain?
M3kanic
http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101
This is the easiest explanation I could find quickly.
If you plan on lifting more than the keys you plan on doing and going with some kind of spindle lift most of of them require a back spacing of 4.5 inches. So that is something to consider when you are looking at rims. That's why I got my rims.
Juiceman74
Juiceman74
So do I need to put a lift on my truck or can I just raise it with keys?
M3kanic
In those pictures I have the Rough County leveling kit. So that is keys, 3/4in rear spacers and shocks.
lalabanks80
