Tire Rubbing/Wheel Well Trimming Suggestions
NorCal Nali
Granite Bay
Hey Guys, So I have noticed that when I pull in/out of parking lots at an angle that are on a slope of any sort I hear a horrible rubbing/grinding sound coming from my rear wheel wells. I checked it out today and it looks like my tires are rubbing against the plastic in the wheel wells. Also on the rear left wheel it looks as if it sometimes rubs against the bolt that the shock is connected to up top and the small AutoRide bar that is near the front of the rear left wheel. I know this cannot be good. What suggestions do you guys have for me??
I'm running 305/50/20's now with a rear shock relocation kit to lower the rear end down a bit.
blueflamed03
Oklahoma
20" rims and what offset, 30mm, 35mm?
The bolt, take off upper bolt and turn it around to where its inside. Plastic, get a heat gun and warm it up, while pushing it backwards. Once it cools, will give you some room.
Limited13
