Tires scrub even with lift! Help plz
yates ™
Resident Apple hater
Iowa
You could get wheels that do not have as negative of an offset.
I am not sure what you want us to tell you but here are your options...
New front bumper, similar to this
Smaller tires
More lift in the front
Wheels with less negative offset (would still probably need smaller tires)
Those are the only options and there are no more.
F
Frankie21
Eastern North Carolina
I really want to try and keep this tire and wheel combo, so lets say i just want to try and get more lift in the front. How do i do this? The lift keys? How are those different from the stock keys?
And in the picture i attached it seems like the bolt for the torsion bars is as far as it goes isn't it? Is that bad?
And that's how my shocks look when its just parked on a level surface, is that how they should be or do i need new ones?
yates ™
Iowa
IDK know much about lifting with keys but different keys can achieve different lifts with different vehicles, make sense? :crazy: Take better pics of the angles of CV and control arms because in that 3rd pic it almost looks like you have a pretty extreme CA angle already.
F
Frankie21
Yea that makes sense, so id basically be putting keys from another vehicle that is meant to have more lift in the front right?
Here are some better pic
yates ™
Iowa
What lift do you have? To me you look maxed out already. Maybe look into 2" lift spindles and decrank the bars to the tune of an inch thus still leaving you an inch higher then now :shrug: Someone with more lift experience on these needs to look at these.
F
Frankie21
It has a 6" Superlift suspension lift.
Iv'e read some stuff about lift spindles but not much, what is their purpose?
This is making it sound like my Tahoe has serious issues. Could you get someone more specialized to take a look? You are TYF famous after all haha.
yates ™
Iowa
Essentially a lift spindle will move your wheel farther down on the spindle.
Not the correct spindles for your Tahoe but shows the difference between stock and lift spindle.
F
Frankie21
Cool deal. Thanks for all the help man. I really appreciate it considering i had a alot of questions and am i newb.
But i have one more question.
Could you link me to some lift spindles specifically for my 01 Z71 Tahoe? And would it matter if they were 2 or 3 inches?
yates ™
Iowa
I am not positive on that but basically they will allow you decrank your Tbars so at worst case if you buy the 3" you will end up with an extra 1" (give or take) of lift on the front.
You would just have to search for them as I am not sure where is the best place to buy them.
F
Frankie21
So buy the 3' spindles, decrank the torsion bars an inch and ill sit 1" higher than now. Easy enough
Do you know of a thread or place that shows you how to install spindles?
Alsherooqi
