To those that have debadged....
Effeckt
Resident Cards Fan
Phoenix, AZ
I removed mine last August with the paint matching up just fine and mine is an 01. I'm sure you will be okay unless something has been repainted. Just do yourself a favor and use the 3m eraser wheel.
DoubleR
I did not have an issue when I debadge my truck. Removed all the glue washed, waxed, and the paint was fine. My truck is green if that helps
TqMnster
Monroe, NC
Just be careful if you try the eraser wheel. ******* at the body shop went this route on my Z06 and burned the paint on my passenger door in SEVERAL spots. I wouldve done it myself but it was already in there cause my wife backed into the rear bumper somehow :(
M.M. 700
I have done it to a Black and Silver Tahoe. Both times you could not tell they were there.
I used a heat gun (be careful) and heated the badges up till it was just hot enough not to touch for a short period of time.
Slowly pull the badge off, and to remove the glue I used the spray can 3M wax and adhesive remover, and a rag(and a blister)
Takes some time but well worth it...
AbroN124
