Tonyrodz's Tahoe Build Thread
What LEDs did you get?
I'm thinking about getting a set for my projectors to try out, but I want a set that are rated for at least the same lumens as the 9011 HIRs I have in there.
When you get them I would be interested in seeing the beam pattern in comparison to the stock.
Here's a pic I grabbed from Amazon. It says they're 12,000 lumes?
Thx Red. I wiggled the he'll out of that yellow wire that you mentioned in another post, but nothing happened. I couldn't get it to go in limp mode. I figured I'd might as well just get it.
It may not go into Limp Mode if the fault happens while the truck's not moving. If you can see a real-time display of what the sensors are telling the PCM, that'd be the way to track it down. Even a scan tool with freeze frame capability should help if a code is set when it happens. It'd be awesome if that Bluetooth one can do real-time so you can watch your phone as you mess around under the hood.
That would be awesome! I'm just gonna wire in the pigtail either way. It happened to me twice today within minutes and it happened to my gf 3 times.
Kingjackpot23
