Tonyrodz's Tahoe Build Thread
You could have an ABS module that's just worn out. I fought with my s10 for a while. Replaced every single brake part. Master, booster, calipers, lines, drums, wheel cylinders, everything. Bought the tool to bleed ABS, wouldn't connect. I deleted the abs with a late 80s s10 proportioning valve. That fixed it. Obviously I tried to keep abs for safety reasons but the ol dime was right at 300k and I wasn't spending $1,200 for a reman abs module. She rolled 362K on my way home from work yesterday:)
not likely, the pedal surge means the abs is working it's just receiving erratic data from a sensor, if the abs was out the lamp would be lit and you would not have any abs function at all, it would be old school brakes only.
AMM1986
