Too Fast for My Yukon?
S7A2G6
I have had my Yukon for a while. Over the years, there have been times I would drive it "harder" than normal. During these times I notice (as I am decelerating) that my lights, interior and exterior, had dimmed significantly. Is this just a normal thing? Maybe a safety mechanism of some sort. Or is it more likely that the RPMs are too fast and my belt may be slipping as a result?
Any insight would be appreciated.
2005yukonxl
No "saftey mechanism" for lights to dim significantly the faster you go....that makes no sense...
but if your lights are dimming when its revving faster- get your alternator tested....sounds like its not charging properly...watch your volts gauge when u do this and see if it drops......
Administrator
X3 on alternator :waytogo:
Campi3ell
Atlanta, Ga
Would it still be the alternator given the problems he experiences are when he's slowing down?
While not lights related, I have noticed that when driving the A/C works fine, but as I slow down the air coming from the vents warms up for a few seconds, then cools back off. Is it the load demanded at that time, and then the change as engine speed/ load decreases...?
04SS99Denali
NY
get your alternator / battery checked. sounds like at WOT its not charging right. it might also be belt slip make sure your belt is tight
Jkrsnich
