Too many issues
Luis Da Champ
Okay I'm having a few problems with my truck. I had the truck parked for a little over a month since I had to go to florida.now when i come back the first issue I have is a a warning message (right rear door ajar). I tried unplugging the purple connector under the brake pedal and nothing change.the second problem is on the driver driver side floor I notice the carpet is extremely wet what gives. My third problem is I was my engine bay and when I finish I went to lock my car and notice my alarm was beeping but the *volume of the beep was really low close to no sound.please help me out and what should I do to * Correct all this issues I'm having with my truck.
Thank you
Administrator
1. I'm assuming the right rear door is closed when getting the door ajar message? If not, close door :) if so, probably just sensor.
2. How's the weather stripping on your driver door? Also check the stripping around your windshield. Sounds like you have a leak somewhere and those are the two places I'd start.
3. Is your battery strong?
Administrator
Deleted a few irrelevant posts :Handshake:
I get into my Blazer one morning after a rain storm and my rug was wet and cup holders were filled with water! It was the moulding around my windshield that was leaking--right in the middle on the top. Maybe you have the same problem? I fixed mine by putting weather strip adhesive under the moulding and it fixed the leak. Definitely look at your moulding.
Bedore
I have had my 2001 Tahoe for over a year, and I could never figure out why the drivers side floor was always wet. I eventually gave up.
I was told to check the windshield seal...which is good. Same with the door seal. I sprayed water all over the doors and windshield to try and find the leak with no luck. Someone said sometimes the grommet where the ebrake cable goes leaks. I pulled back the carpeting and saw the grommet and put a ton of rtv around it. Still no luck. Never did find out what caused that to happen. Just one small problem in a list of neverending issues I have had with it. You might try checking the grommet. Good luck.
Luis Da Champ
Luis Da Champ
thanks guys im going to check the grommet for leaks and also im gonna order the solenoid for the right rear door to see if it will fix the problem other wise im gonna have to get a new ecu and have the dealer reflasehd.
---------- Post added at 03:40 PM ---------- Previous post was at 03:33 PM ----------
does any know where i can find the door selonoid or which part number it is.
Luis Da Champ
Luis Da Champ
My water leak issue was the drain holes around the sunroof one of the was clogged hopefully that will fix the problem
big_b_in_PA
Billy Badass
Central Pa.
Cool, that should take care of the water problem. Im not to sure about the rear door sensor though. But the sensor/ door problem may be why your alarm was going off, though.
Luis Da Champ
Luis Da Champ
Water leak is still there not sure what to do I know for a fact is the sunroof where the water is coming in because is leaking by the ac control on the roof.
big_b_in_PA
Billy Badass
Central Pa.
Check the seal around your sunroof glass, you may have to adjust the glass panel. I don't know what else to check.
Jeremytahoe
