I say it’s a failure caused by two things. First, Rough Country hubs are not hub centric, I looked this up. This has been a known issue with our trucks because the weight is completely supported by the studs which is not how our hubs and wheels are engineered. The hubs are supposed to support the weight and the lugs hold the wheel to the hub. Second is they were probably not installed correctly as in the wheels were never removed and the lugs that hold the spacers on weren’t re torqued which resulted in the spacers working back and forth on the studs where if they were hub centric you would notice a wobbly wheel before it failed because weight would still be on the hub instead of completely on the studs. But it’s only an opinion and I doubt we will ever know. This does have the classic symptoms of non hub centric wheels or spacers though.
