cbepro
- Joined
- Jun 22, 2014
- Posts
- 31
- Reaction score
- 0
Hey my first post!
So i'm kinda new to IFS and just installed Ford keys and they got me the clearance i needed to run 315/70/17 with trimming and very minor rubbing on the E-brake cable on the drivers side at full lock. **I also rotated the torsion bars when they were loose before final install of the Ford keys.** Upon final install of the keys, i just let the key rest on the adjuster block, then put the adjuster bolt through till it got a lil tight and i was satisfied with the new lift.
Yesterday i finished install on Cognito upper control arms. They are resting on the upper stop that limits down travel when the car is sitting on it's own weight. Obviously this means i will hit metal-to-metal when i go over a speedbump and have zero downtravel. I thought about cutting the upper down travel limiter and doing limit straps (which Cognito recommends the limit straps, not the cutting).
But my question is i completely removed the passenger torsion key adjuster bolt, so the torsion key is resting on the block the bolt goes through. Shouldn't my passenger ride height be lowered? Did rotating the torsion bars cause this result?
Im trying to lower the front a lil bit just to get the upper control arm off the bumpstop.
Pics are of the torsion key with bolt removed and how the passenger front sits without the bolt installed.
