Torsion Key Leveling Kits - Are They a Scam?
corvette744
2004 Z-71
Northern illinois
I’ve had people try to tell me keys make the ride smoother because the bolt isn’t cranked as far. But regardless your ride will be a little be rougher
tahoe new tires and rims and lift kit 010.JPG tahoe new tires and rims and lift kit 011.JPG Stock ones max at an inch and if you max them out it for sure makes it ride rougher.I needed 2.0 inches in front so i went with ready lift 2.5.Installed the bilstein shocks and it rides almost softer than stock-Love the shocks made a big difference in the ride. Spare tire 037.JPG
Ryan Buck
Mesa Arizona
truth be told. i had the bolt at its min use with the new keys on my HD made the lower control arms forced all the way down, they had no spring left to them, if you hit a deep pot hole the truck fell in the hole, but with the plow on it it rode really smooth. they also broke two shocks, snapped the shaft like a twig.
why i got a bad taste in my mouth from them. but like i said, the 1500 bars might be a lot softer and make it drive closer to normal. only used em on the HD truck. so thats all i know firmly about.
they lifted the front so much i was able to run 2 inch blocks in the rear and it sat level.
When you broke the shock, did you have the 2 inch extenders installed
Scottydoggs
NJ
i had a longer shock, issue was the shocks could not even work really. i didnt even know it broke, notice it during a tire rotation.
RET423
The more bolt you have driven above the key the more likely the bolt will bend and/or break under a load, keys indexed for lift enable the extension of the bolt to remain well within the factory parameters; so no they are not a scam.
CJ Rodarme
CJ Rodarme
Kent, WA
Oh I didn't even think of that, and in that case it does make sense to use them
Mr. 960
But then again you can only do so much before the front tires start to angle in, and the UCA is resting on the upper bump stops - correct?
CJ Rodarme
CJ Rodarme
Kent, WA
Yes, from my experience that’s what cranking leveling keys to the max will do
ScottieGirl
