Torsion keys installed wrong?
HoeRyder26
Mass
Hey guys, just installed my Crown Suspension 3/4 kit. Everthing went excellent but to install the front keys I did not need the torsion key tool to compress the keys to slide the bolt assembly in. I was able to just push up on the key and slide it in by hand. Also the bolts are tightened almost all the way. Are there left and right keys?
jough
Arkansas
I'm guessing that you need to remove and rotate the keys to the next flats on the torsion bar.
HoeRyder26
HoeRyder26
Mass
I wonder if I swap sides if it would help. I tried rotating the keys both ways and it seemed to be way off, one was stuffed in the channel and the other way pointing to the ground almost, there would have been a LOT of tension. I'm using my phone right now so I'll try to get some pics up. Also I would like another inch in the back if possible, do springs eventually "break in" or would I need 5" lowering springs?
Aaron_L
Arlington, TX
They are under a lot of tension. You shouldn't be able to put it together by hand. The coils will settle a little after a few days.
HoeRyder26
HoeRyder26
Mass
Drop keys, also I failed to mention that I did this on a post lift. So the wheels where off the ground. It just seemed odd. Bolts are both cranked almost all the way and it sits at its 4" drop.
tahoe_highcountry
