Tow Haul issue
ehames005
I just bought a 01 GMC Yukon. I brought it home and the next day when I start it the tow/haul light was on. I pressed the button and nothing, after a few minutes it shut off by itself. I'm pretty sure I have a short in the wiring. My question is, is there any way to completely disable the tow/haul function? I do not tow any thing as of this time and it is just annoying.
cxs4887
mine did this not long ago at all got in for no reason stuck in tow haul then it would go on and off. driving sucked. on your gear lever pull that boot out and take off the bottom plastic piece under the wheel theres a wire mine was orange i would bet money same as mine it got brittle and broke. i just butt conected it back together worked fine reasemble good to go. as for disabling.. not sure
Just like the others said, there's a pair of wires going to that switch that always break or short together. If you just tape up the ends you'll disable it. They get caught in the shifter.
Fredrikswe
