Still here, but I don't play around with PIDs so much these days. I have figured out most of the ones I wanted for the Tahoe. I drive a 2021 Escalade most of the time now and most of those PIDs don't work on it. GM has changed them in the newer CANBUS and Global-B protocols.
I figured out many of those PIDs by capturing the data stream between my Tahoe and Tech 2 while scanning the things I was interested in. Then I combed through the data and tested parameters by trial and error until I found the PID I was interested in. In some cases it also required working out the proper header info as well, if it was from a different module other than the ECM (for instance, the tire pressure data is, if I remember correctly, requested from the instrument cluster). GM has moved to a new diagnostic scanner since then and the technique that I used on the Tahoe with the Tech 2 doesn't work on the newer vehicles, so I never figured out the PIDs for those things on my Escalade.
It was complicated enough in the 2005 models, but the newer vehicles have so much going on that, frankly, I lost interest in trying to work it out in them, and I don't have the newer MDI scanner to use on them. Torque is capable of reading most of the info, if you can figure out the PID parameters, but it's become a pretty big job to decipher them these days.
