TPMS Problems
latvius
Ariton Alabama
When I bought new tires 1 year ago I bought all new tpms sensors (off brand) then a month or so ago one went dead, no communication. So I bought 4 new AC delcos and had them installed.
The LR started to disconnect and reconnect every so often. So I bought another new AC delco and took it to the tire shop. They said all it needed was a relearn and didn't swap the sensor.
Drove it about 10 miles down the road and same thing happens no TP LR, so I take it back and ask them to you know do what I asked them to do in the first place LOL. So they swapped it out.
I verified the LR tire had been dismounted and got the old AC delco sensor out so I could return it.
It started doing it again and sometimes the RF goes out, neither at the same time.
So it doesn't appear to me to be the sensors and the tpms module is part of the BCM (from what I read) so I am at a loss on how to fix it.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Since it is intermittent and you have used TWO AC Delco sensors, I would go right to the BCM and check where it lives for any problems, remove it and inspect the wiring to it, unplug it and inspect EVERY male/female connection and even use some electric cleaner spray and then reconnect and reinstall and see what happens. If that does not fix anything or produce better results, either tape over the light or run it off a cliff.
Sorry, I have a short fuse today.
TJ Baker
Colorado
All tire pressures are sent together in a single message from the PDM that the cluster receives. So it is not likely to be something like a wiring issue or all sensors would drop out together. The messages are sent quite frequently as seen here in a screenshot of a search of a logfile I have. Each line is another report of all tire sensors.
Daddyyukon92
