Traction control/stabilitrak message
shreksbrother
Auburn Hills, MI
2012 PPV, stock tire size is 265/60/17.
Today I put on a set of winter tires, 245/65/17. They fit without issue. When I took the Tahoe around the block, I got the message mentioned in the title.
According to tiresize.com, the winter tires are the same overall diameter. Three of the tires are at about 8/32, and one is brand new and 13/32.
Is it possible that one brand new tire is causing the message?
Any other suggestions?
Sent from my Galaxy Note9 using Tapatalk
kbuskill
NE. FL.
Definitely possible... the difference in height translates to a difference in wheel speed so the speed sensors for the ABS may think that one wheel is spinning/losing traction.
shreksbrother
shreksbrother
Auburn Hills, MI
Thanks, I suspected the same. I have one of those fancy scanners that displays wheel speeds in real time... Maybe I'll hook it up on the way to work and test the theory.
BigBodyBurban
