Traction on DIC coming on more often
sounds like one or more the sensors you installed are bad, you really need a scanner that does ABS in order to tell
BlueCollarTahoe
BlueCollarTahoe
came from the mechanic...after some diagnostics...its been confirmed its where the sensors plug into in the wheel hubs...so wheel hubs need replacement. now should i go timken or acdelco? need to order these today
BlueCollarTahoe
BlueCollarTahoe
need feedback before i order...told me to order the best i could afford hub assembly with the sensor
cjprod0684
