Traction Stability Sytem (Help)
coljenmel
Hi Everyone
My Traction control stability system make a noise everytime I pull away from a dead stop even on complete flat dry land . Its like the truck thinks its slipping or something so latley I have been pushing the botton on the dash to disarm it so it stops making the noise
Sasquatch
Orange County N.Y.
I had the same problem on my yukon and it was a bad wheel speed sensor, It was mis reading the actual speed making the computer think it was losing traction.
The sensor that was bad was in the front of my truck and the sensor is located in the hub bearing. I`m not sure where the rear sensor is located.
I was still under warranty so i had the dealer diagnose and fix the problem.
QUYHMK
