I have never done it, but I would test from the actuator back to be sure that is indeed the problem, when you press the button the actuator should be getting power, if it is getting power then you know it is bad, if it is not getting power then keep going backwards until you find the source of the problem. once you are sure the actuator is bad order the replacement then that should give you a better idea of how it comes off.Thanks....is anyone familiar with how you take that whole assembly off? or is this done with the 3 that are some type of star tool and screw in backward?
