Tranmission Fluid flush and filter change
Shipyard
Yorktown, VA
Yesterday I just did just a first flush on a 2016 with 6L80 at 50k miles. I used method where the transmission’s pump does the work using the return line and Hayden 397 fitting/hose. About 14 qts resulted in much cleaner fluid cycling through. I plan to flush again at 75k miles and again with a filter change at around 100k.
Theres lots of videos and threads out there for a DIY flush, but one confusing thing for this year/model (2016 with 6L80 without towing package or aux cooler) was figuring out what line/fitting on the trucks trans cooling system to use… some hook up at the thermostat. For mine, the return line fitting is in a tight spot on the drivers side on the bottom of the radiator. Also the line needs to come off the close-by hanger as it’s pulled out of the female fitting.
Also… With mine warmed up to 180, I didn’t have any fluid pumping out of the pulled off line (because of the thermostat) in addition to the discharge hose. I did have a hose on that line too though, just in case.
Bob2C
Northern VA
You should change your thermostat as well. Mine runs about 150 max 160. It’s an easy job
Shipyard
Yorktown, VA
Mine normally runs cooler like yours does . I wanted to be certain the temp was up so it would pump through the return line… so I drove it harder than normal for the 15 minutes before getting home. Towing a 4500 lb trailer in the summer, it didn’t get over about 195 if I remember right.
bruh2125
