Tranny flush on 03 tahoe
jackmono
Can anyone give me detailed how to on flushing my transmission fluid. It's an 2003 tahoe. I recently changed my fluid but it's still brown in color. I assume it's because it's mixing with the older fluid left in the system
Scottydoggs
NJ
if you get fittings to fit off the trans lines off the rad you can use two buckets, one to catch the fluid coming out, the other filled with new fluid and suck the fluid up with the other line. idle the engine till you got red fluid coming out the draining hose. use clear hose too. im sure theres a vid on yt to follow along.
then again, if your fluid is black, that trans might be on its last legs, if its acting up a fluid swaps not gonna fix it, actually might kill it the rest of the way.
Emshelton5
