Transfer Case 4 X 4 Indicator Switch
mfawcett
Hello all
I have a 96 tahoe 4dr 5.7 I manual floor shifter can't get the indicator light to come on in 4H or 4L. I just replaced the 4x4 acuator which was bad and it seem to be working fine but no lights would that mean Transfer Case 4 X 4 Indicator Switch is bad is that is only function?
Thanks
TxTooTall
League City, Tx
pull the cover off of the floor cover, I'm pretty sure that there's an indicator switch there. The contacts might be bent a little
kcb37
Are you sure it's not going into 4wd?
Just asking could be a burnt out light.
If it does, start looking. (2nd 4wd for me) but I though it was just on the transfer not in the cab/under.
Gzes
the drifting 2dr
Wichita tx
one of my plugs is burnt out on the floor shifter the other works butflickers. its just a short somewhere probably same for you
Roblusk
