Transfer case died :(
ERIC95TAHOE
Southern Wisconsin
so i was driving down the highway today with the windows down, noticed a strange noise when i hit some bumps, thought wtf is up with it now, got it slowed down and into town and it started grinding loudly on acceleration and when hitting bumps, 99% sure its the transfer case. put it in 4wd and it goes away. drives just fine, just makes a terrible noise. if you hold onto the 4wd gear selector you can feel it when it makes the noise... :emotions122: gotta make a trip to Missouri in 2 weeks so now i get to hunt down a transfer case for a good price, anyone got one around southern Wisconsin they would part with for cheap? just figured id share my story :emotions34:
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
i found one at a junk yard for 350, and im seeing rebuilds go for up to 800.
i was thinking maybe i could take it apart and do it but i cant quite find a whole rebuild kit. it sounds to me like the problem is in what engages 4wd. its always had a bit of a grind going into 4wd and thats the noise its making all the time. i was thinkin about driving it to work today and taking it out after work.
if i put it in 4wd it goes away if i back up it doesnt make the noise. it has however since i bought it made a popping noise when backing up and turning.
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
found a used transfer case in a junk yard 45 miles from here for 175. swapped it out yesterday and she drives just fine again
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
never even thought to replace the rear seal it was leaking today, so i figured id replace it, i started pulling the seal and cracked the housing luckily i still had the tail to my other transfer case laying around all is well now and shes ready to rock n roll :headbang:
Ispa805
