Scotty54
- Joined
- May 10, 2019
- Posts
- 16
- Reaction score
- 12
Vehicle is a 2006 Z71 Tahoe with auto 4WD and Stabilitrack.
My T-case has trans fluid in it right now. I checked the manual and it's a little confusing. It says for AWD with Stabilitrack use Dexron III. I think I jumped on this seeing the word "Stabilitrack" and that's what I used last time (the only time I had changed the fluid). Now I see for the auto T-case I should use Auto-Trak fluid. Can some of you confirm this?
If I have been using the wrong fluid for the last 50k miles, have I caused a problem? I have only been off-road once but I frequently shift to auto 4WD and 4HI just to keep things lubricated. Everything seems to work fine.
