I have a 1996 4x4 Tahoe, been having problems with the 4x4 system, I traced the problem to the transfer case encoder / shift motor.
I purchased a new Dorman part and having a problem trying to install the motor, the new motor came with a plastic plug in the female lug of the motor which tells you it's in 2wd position (as per the instructions), but it won't line up with the shaft coming from the transfer case, I can rotate the shaft from the transfer case using a 14mm open ended spanner but the only position I can make the two line up is with the transfer case in 4wd high, does anybody have any thoughts, I don't want to carry on and break the new part.
