Transfercase volume?
ktmhans
Connecticut
Does anybody know the capacity for transfer case. I have a 2004 tahoe awd. I beleave its a borge warner it takes atf merc III. Figured id go RP.. Looking at the fill plug it doesn't look like more then 2qrts.
Thanks
Sorry if its here somewhere search doesnt work well with my phone.
taylorjm
Saginaw, MI
I'm not sure about a 2004 but my 2003 only takes the blue fluid you have to get from the dealership and used almost 2 quarts.
K
ktmhans
Connecticut
that sight it great! thanks, Im thinking i must have the od ball one. I only put in 1.5 qts or so and it brought it to the plug. I took it out for a little ride and checked it agian and it was just below the plug hole.250" or so. right what the manuall calls for. geesss. i have never been so nervous with changing fluid before. like 2.5 qrts came dumping out when I drained it. In hind sight I loosened the fill plug but didn't completely remove it. If I had I would have noticed if it was overfilled somehow. I checked twice in the manual and once at the dealership with my vin. and yep it just took DextronIII. So I put in RP Max ATF.
Lets hope for the best.
taylorjm
Saginaw, MI
So does your tahoe have the selectable auto, 4hi, 4low transfer case? I never heard of an awd version.
K
ktmhans
Connecticut
nope, it just has stable track. I can take off traction control but its in never going to just break the tires loose. Ya I never knew about the AWD ones either, though those were just the denali's. the truck was pretty clean and the price was right. Also I've read that it is a different transfer case then the Denali's as well, mine is borg warner.
txfb
