Swapping out the radiator and the tranny line flare fittings are a problem. One I THINK is sealed. The lower leaks bad. Fitting is tight. Tighter than my fuel filter fittings thats for sure.
What can I do? Try the old fitting? I bought some permatex teflon sealer but the flare should be sealing the joint and wonder if gunk on the threads would even help.
I'm so frustrated.
Thanks in advance,
I'm so frustrated.
Thanks in advance,
