Transmission Fluid Temperatures
YukonXLMan
YouTube has a few 6L80 Transmission thermostat delete videos detailing thermostat removal, tapping and plugging the port that allows trans fluid to bypass the trans cooler. and reinstalling. In scouring the comments on some of these videos, one person stated they simply took out their thermostat, turned it around and reinserted it to block off the same port, thus making the entire task much easier to accomplish.
Anyone have any experience doing this mod and if so, what's your opinion on the thermostat reversal method, vs. plugging? One person doing these mods in Arizona says he drops the cooler temp to about 175. For me this would be awesome, however living in the North East I'm thinking this may have deleterious transmission consequences during winter on my 2017 Yukon XL. Thoughts?
P71toZ71
Based on my experience, without an added cooler, the trans temp will hover around 100 degrees above the ambient air temperature, whether stopped or moving. So your max temperature is highly dependent on your climate.
With an external cooler (factory or aftermarket) the temperature will be lower, but it will fluctuate more. When the vehicle isn't moving and the radiator fan is off, the temp will creep up. The fan will cool it some, and moving will cool it more.
One thing to keep in mind when deciding what temperature you don't want to exceed is the location of the temperature sending unit. If I recall correctly, it is measuring the temperature after the fluid has returned from the cooling system. The temperature of the fluid leaving the transmission is going to be somewhat hotter.
Hills and towing will absolutely put a greater load on the transmission and generate more heat. Personally, if I were towing anything more than a small utility trailer, I'd want at least a small cooler in front of the AC condenser. If I were regularly towing a few tons, I'd want a large cooler. I added one myself and I have not noticed any decrease in AC effectiveness or increase in engine temperatures.
SuperOldSchool
Don’t worry about it. Just change fluid according to severe schedule.
GoPadge
