Transmission Identifications
xczar
Northeastern PA
Hello, ......... I tried doing a few searches for trans id`s here with no luck. I am the original owner of a 1997 GMC YUKON 2-door/4WD. I checked the trans pan bolt pattern, it has 16 bolts. But, need to confirm which trans I have. 4L60? 4L80?
Reason for this, evidently, to get the correct 02 sensor, I need the correct trans ID. I pulled a OBD: P0155 code and need to get the damn engine light turned off.
Thanks for any info you may have?
Xczar
Gzes
the drifting 2dr
Wichita tx
You should have the 4l60. A universal o2 sensor would work fine just would hav to pin it to your plug but that's super easy
Roblusk
