TRANSMISSION OIL CHANGE
these people going 100k are the ones you see on the used lot with black transmission fluid.
I wouldn't go over 40k without a change, I do mine about every 25k
I am poor I need these vehicles to make it 10+ years, that means maintaining them, not just driving them until I trade it in for another one to ruin
*and transmissions use transmission fluid, not oil.
dougo
Raleigh
I suck the fluid out with a oil extraction pump the through the dip stick 3.5-4 quarts out and replace it once a year , at the 50K I have it flushed or do the same process 3 times, I tow Mutiple trailers and like Doubelive i am poor and need my truck to last 06 192K In my opinion trans fluid is cheap when found on sale and easy changed with and extraction pump
DonutGodd
I’ve heard too many times from actual transmission guys to do it twice as often as the manual suggests. Last time I did it on my 18’ Yukon I installed a PPE pan and a thermostat reroute too. I can’t stand not having a drain plug. Added a little capacity as well.
tom3
I bought a transmission thermo valve to put on mine when I change it, but I've been watching the trans. temperature and highest I've seen is 192 and that was in a 20 mile traffic jam inching forward. Usual highway and in town is 170s into 180s now and then. Still changing it though since GM actually recommends it.
Hobbitsam
