Transmission shifting weird issue....
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Remove or Disconnect
Negative battery cable.
Disable SIR.
Retainer from brake pedal pin. Use snap ring pliers.
Switch by unsnapping from pushrod.
Electrical connector from switch.
Install or Connect
Electrical connector into switch.
Switch by snapping it onto pushrod.
Retainer onto brake pedal pin. Use 11mm (7/16 inch) socket to push new clip on pin.
Enable SIR.
B
Bowie
What switch is the SIR switch, there seems to be a lot of wires down there? Is ther anything I can take out so I have some more room in there?
Thanks
raptorforme93
Tampa, Fl
If your truck's temp is lower that a certain degree (I don't know what exactly) the computer won't let the tc lock up. If your thermostat is stuck open your truck could be running too cool and that could be the cause for your problem. So watch your coolant temp and see if you need a new thermostat.
Is this why my hoe never shifts at 50 mph when I have just started it on a cold day? I get up to 55 or 60 mph and it doesnt shift until the truck has warmed up to normal temperatures. I figured that it was something like what you said but I was never really sure or cared much to ask since it always shifted once it was warm.
SunlitComet
OBS Jedi-Do Good
Bowie: with key out of ignition lock pull your airbag fuse. #8 I think. Then disconnect the only the yellow colored connectors under neath the dash. At least one but maybe two if your have passenger air bag. Proceed with repair. Reverse the procedure to re-enable SIR system.
Don't want you to get hit by a false airbag deployment. :)
---------- Post added at 04:51 PM ---------- Previous post was at 04:47 PM ----------
Raptor, iirc the temperature can kill off the overdrive gear as commanded by the PCM. You should be just fine. It is SOP in the PCM. Good enough or should I find some details for you if possible?
EastTXYukon
Longview, TX
Wow! Learning a lot today. My truck does the same thing as Raptorforme93's. I thought it was a problem, but just one I had to deal with on a 15 year old truck with 150k on the transmission. I had no idea that the tranny not shifting into overdrive until it was warmed up was the correct way for it to operate
Thanks for the info Sunlitcomet :beer:
B
Bowie
sunlitcomet
I wanted to say thanks for all the help. I could not have done it without you. It has been running great so far, hopefully it keeps up.
The one question I have is: Did I do any damage to the Torque Converter. The tranny had been shifting like that for 5 years or more.
Thanks again
raptorforme93
Tampa, Fl
No youre good man :) Thank you though! I figured that it probably wasnt a big deal since everything drobe normal and it did it consistently until the weather warmed up. Thanks!
SunlitComet
OBS Jedi-Do Good
sunlitcomet
Thanks again
Ouch. Maybe some extra wear and tear on its clutch. five years is a long time. If you do get a code for a or notice slipping tranny you will know where it is slipping. Just run it till it breaks.
crxx
tn.
had the same problem and such an easy fix! Amazing how a lil $10 switch could handle so much. And thought i was gonna need a new tranny....smh
insadj05
Iowa
Additional questions
Sunlit,
I was driving home today with the 99 tahoe and the rpm's were drifting between 2100 and 1900 like above. However when I pulled off the interstate for the 14 mile back woods trip to the house every I stopped and started I would get hard shifts. Would this switch be causing this also?
Thanks
hosleyb
