Transmission slipping in 4wd
Barrow 171
Hello everyone,
I have an 05 Yukon that we took out on the beach and the 4wd hi started to slip under the load on the sand and the truck wouldn't move. In 4 low it would but not as it should. No problems shifting or driving on pavement so i am assuming there is something wrong in the transfer case. Any ideas where to start would be greatly appreciated.
Thanks
Fless
Super Moderator
Elev 5,280
Welcome to TYF!
Tell us a bit more about how the 4Hi "slips." Do the rear wheels spin but not the fronts? Kind of like it's in the Auto mode?
Hello everyone,
Thanks
Welcome Nick, please give us a little more info like Steve said.
B
Barrow 171
This past trip when we started out it was fine. When it started it felt like the truck was just bogging down and losing power in 4 high. The harder you hit the gas the less it did until it stopped and gave off a almost hot brake smell. In 4 low it would move but very slowly and not as it should. In 2 wheel it drove fine but in the deep sand 4 hi was needed.
B
Barrow 171
Also there had been a couple of times over the past year when atart from a stoplight the the truck hesitated before taking off. I have used the truck to pull trailers and boats often and never had any problem with the drivetrain except for those two times and on the beach.
I would inspect the brakes, specifically a sticky caliper or worn slides or guide pins. Truck is 15 years old, when was this stuff last serviced/replaced?
We had one piston on one side up front stick a few months ago, caused the steering wheel to shimmy. When we took it apart, the piston was out a little bit, pushed it back in, greased the slides and put it all back together and has been fine since. It had been about a year since we did them but calipers and hoses are original.
