Transmission Temp 180
playadude
Hey guys,
I really baby my Tahoe, transmission temps around denver are 144. I noticed it was climbing up to 180 on the way down the mountain from Vail last night.
Is that excessive ?
Thank you
MichaelSE
2010 2500
Tucson
No. Generally >240 is the danger zone. Mountain climbing, especially if you're punching it, will cause it to rise quite a bit. I used to have a Suburban 1500 when I lived in El Paso, and touched 200 degrees a few times while accelerating up Trans-Mountain.
If the transmission temp rises while idling, or rises as you put strain on it and does not drop once you start driving on flat ground, it could be indicative of a transmission cooler/cooler line issue.
dbbd1
Hey guys,
Is that excessive ?
Thank you
The thermostat on the trans doesn't even open to the cooler until 180*.
NYisles1
My ‘16 Suburban usually runs near 190 on long trips. Within the normal operating temp referenced in the manual.
enginerd3
