Transmission whine or ?
PNWYukon
Olympia, WA
Anyone else have this issue? At low speeds the Tahoe will make this whining like noise but it seems to disappear at above 20mph, unless the truck noise covers it!
I put it in neutral to see if it is belts or pulleys, but no noise until transmission is engaged. Some have suggested tran-oil pump is clogged or that is is rear trans bearings?
Any suggestions will be appreciated.
Choadmon
I have the same issue. People have told me it is a gasket in the tranny pump that breaks. I've been told that it isn't a major issue right away but in time, your pump will go bad.
Jack23fcb
