Transmission?
cshupe
I have a 97 Yukon that I recently put a used transmission in. When I am in OD it feels like it is slipping then catching, mostly on an incline but sometimes on flat ground. I went out of town yesterday on the interstate and when I switched to third gear it was fine. Not sure what is going on. Any thoughts?
Thanks,
Chris
Diller
Cedarburg, WI
Thanks,
Chris
Possibly a TCC PWM (Torque Converter Clutch Pulsewidth Modulator) Valve. My 99 does this from time to time.
Diller
longstand
Dude, put Lucas Transmission FIX. it will fix it.. Put a whole bottle
retorq
Kingman AZ
Did you rebuild the used tranny?? How many miles was on it?? I would agree it's probably the converter locking and unlocking. These 4L60Es are know to wear out that bore, the only way to fix is to drill and bush it ...
C
cshupe
Transmission was supposed to be recently rebuilt? Will a new torque convertor fix it? When we installed it the torque convertor wasn't seated properly and we put quite a bit of pressure on it before we realized it. Could the convertor have been damaged?
longstand
I heard alot of good Review about the Lucas Tranny FIX, its less than $10, just try it,
after you Pour the Lucas Bottle, after 60 Miles of driving it will get better.
weird. but i had low Oil Pressure and i got some lucas and my pressure was back to normal. :party33:
retorq
Kingman AZ
If that is the case you didn't hurt the convertor, you hurt the pump. I've actually seen guys snap the ears off the pump from installing a convertor 'wrong' or trying to install it when the tranny is still in the vehicle. Even on a rebuilt trans, if they didn't specifically address that pulse solenoid issue it can still be the culprit. It's typically outside the scope of a normal rebuild ...
---------- Post added at 11:22 AM ---------- Previous post was at 11:22 AM ----------
You should pour some on your headliner and see if it fixes that. If it does pour some on your tires next. :D
longstand
To late retorq,, I already did. and by my Amazement it WORK, OMG it work, this stuff really work..
Fingers
