Tune Up
Danny3737
I removed the inner fenderwell cover to get access to the hard to reach ones.
Believe me, this tiny extension on the plug socket is the way to go. No need to remove anything, nothing else needed. It makes it so easy you'll be amazed.
David Paul
Central NJ
i used the delco replacements. Everything went fine, with the exception of i had a tough time getting the new plug to thread into the drivers side front cylinder, i forget which # that is. Thought i had stripped it, but after some patience got it back no issues.
I had the same problem. Got the plug in and am hoping it's not cross threaded. No leaks or issues for 10,000 miles.
Danny3737
It helps to put a little dielectric grease inside the boot to help slide it over the plug
hessdawg
Ac delco has $3 off each iridium spark plug
$2 off platinum rebate going on right now
LaOrange
River Ridge La
Hi All
I put a little anti seize lubricant on the threads.
I changed the first set at about 100k and getting ready
to do it again as I have 207K miles now. I changed the wires
the first time.
Danny3737
I really don't like putting anti seize on the threads because there is a good chance of over torqueing and stripping the threads. Its a big no-no when installing plugs on aluminum heads. I just thread them down until snug, then give and extra half turn.
