Turn signal LED resistor...
Fast55
Ventura County USA
You want the 6 ohm 50W models from V-LED's. They are able to dissipate twice as much heat (50W VS 25W). You're not looking to match the wattage of the bulbs, and no LED is even close to 25 watts. I also recommend finding a spot to mount them to the body, or better yet, use the mounting plates and then bolt them down to something, they will run much cooler.
Smoove
Smoove
South Florida
Are these needed for the LED tail light replacement bulbs that would fit into the stock light bulb sockets (found on ebay) or for a different LED taillight?
Correct
---------- Post added at 04:58 PM ---------- Previous post was at 04:34 PM ----------
-Ordered.
Thanks EVERYONE, I appreciate the insight/knowledge.
Ann G
