Turn Signal Relay, 1999 Yukon
jvc2112
My turn signal relay keeps clicking even though the turn signal is not engaged. It usually stops when I apply the brakes but it's getting worse.
It's like having your turn signal on all the time. Driving me crazy.
Is there an easy fix or will it cost me a lot of money to fix?
Thanks.
J
jvc2112
for someone who has never taken apart a steering wheel, could I encounter problems or it it fairly straight forward? Thanks for your help.
bsamoul
Hoe Enthusiast
Walnut Creek, CA
Well, you'll need a steering wheel puller. That's about $20. Pull the airbag fuse, disconnect neg terminal if you want, pop the airbag off by the 4 holes in the back, loosen nut with socket, attach wheel puller and release the wheel.
Timqua
