SnowDrifter
- Joined
- Sep 5, 2016
- Posts
- 2,445
- Reaction score
- 2,688
Excuse my while I be skeptic for a sec
What are you solving for? These rigs were designed and built in Texas(ever wonder why these seem to drive best at ~80mph?). Not like they didn't consider heat.
My 2 cents: Convert to efans, while you're in there, flush your cooling system with distilled water, throw dexcool in the garbage, and put honda coolant in it. (PEAK # PAB0B3). Mind your dilution as you'll be adding concentrate to a system filled with distilled water. I usually target 60/40.
Lower temp thermostat is a waste of time IMO. All it does is make it open sooner. Do you want your engine to run at 170? or 200? Open is open. You'll get no more cooling out of a low temp tstat.
FWIW on my '05
- It has efans
- I run the honda coolant mix I suggested
- hottest I've had it was 118 degree weather. Coolant temp was 206. Honestly it was the trans that was struggling the most with temperature. Was in the high 140s with a trucool 40k.
- I used some diodes and wired in a manual override switch for my fans so I can tick them on if I arbitrarily decide I want them to run faster than the PCM wants
FWIW on my '05
- It has efans
