Underhood blanket thingy
MotRhead
Alberta canada
i know im using pretty technical terms but stay with me
the insulation type blanket under the hood , does this serve a special propose?
mine looks ratty and i have always taken them off my other vehicals
if i take it off is my truck going to self destruct? ( more then it already is? )
Brandon X
Michigan
If im not mistaken they absorb heat and keep engine noise down?
I dunno, kinda just guessed to be honest.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
yes they serve a purpose. They absorb heat. Bad idea to take it off espically if you live in cold areas. Engine will heat the metal and the cold will cool it rapidly causing Paint to peel and maybe even warp it.
drowndindreams
Unknown
Yes, that's a heat and noise shield. If you take it off your engine temperature will rise significantly and you'll hear your engine 24/7.
tbert321
Connecticut
I also believe another pourpose for these is in case of an engine compartment fire. If a fire starts under the hood the little plastic clips melt dropping it onto the burning compartment hopefully putting it out. My suggestion if your asking would be to leave it in place.
GMgarbage
