Underhood Storage Box Retrofit?
Justinj360
Has anyone ever tried to take the underhood storage box out of a late 90's GM truck and fit it into the 2000-2006 trucks anywhere in the vehicle? I'm thinking it would be really cool and handy to have this. Will it fit easily under the hood in these newer models?
NGAneer
NWGA
Bump. Want to do something like this.
BirchyBoy
I bought one for my '99, thinking it would hold a bottle of oil and a few other things. It isn't tall enough for the oil to stand up, and there are holes in the bottom so it isn't water-proof. It mounts to a plate that is already there with "snaps" on one side and a bolt through the fender well on the other.
If I were you, I'd try and find something made for your truck or make one yourself if you have a spot for a second battery.
NGAneer
NWGA
I'm going to do a sealed battery box. Just wondering if anyone else has something similar.
Justinj360
Justinj360
I took about 2-1/2" out of the middle of mine to make it shorter. Then zip tied the 2 halves together. Also cut off that weird little piece that stuck out of the back. It's even less waterproof now but I was only planning to have larger items in it. Could always seal it up with duct tape haha. There still isn't a great spot for it that I've found. There's a spot behind my coolant reservoir that would be good but it has a bracket going over the top of it so you can't open the lid of the box. But it will fit there. I thought about mounting it to the frame somewhere too... And also upside down under the hood where it wouldn't hit anything... Just brainstorming here. Any other ideas?
Justinj360
Justinj360
I had never heard of that... Oh well, it's sturdy and will work just fine for me
Wannabez71
