Undo the magnitude bypass
John Sw
I have a 2015 Sierra Yukon 1500. I already bought the original magnaride shocks for the front. Started the job only to find out previous owner replaced the magnarides with a bypass kit AND cut off the car side connector. I have 2 questions….can I use the new magnarides without connecting the harness? Second, are the two wires on the car side signal/control wires or 12 volt, or one of each? I get no voltage reading on either wire with car running.
Moved you here from General Discussion, since this is a suspension issue.
the wires will provide a small electrical current to the shock and read the ohm's when they are connected properly, you can buy replacement harness connectors online.
unless there are connected the system is useless and will just default to whatever ride the shock provides without a computer connected
just search "genuine gm connector shock" on ebay, there are many
Welcome to the Forum from NH.
Pics of the truck, please.
As stated above, you can replace the missing harnesses. Check to see if the position sensors are still attached to the suspension arms on all 4 wheels, as they are part of the Magneride active suspension system as well.
Might want to edit the thread title so it says Magnaride instead of magnitude. Or not.
mconrad58
