Upgrade Your Chevy's Performance with aFe Momentum® Air Intakes
carid
Supporting Vendor
Cranbury, NJ
If your Chevy Tahoe is often seen hauling loads, or conquering off-road trails, make sure it delivers maximum horsepower to get the job done.
Today, we’ll take a closer look at the Momentum® HD Stage 2 Cold Air Intake System, engineered by aFe to increase the flow of cooler air to your engine and deliver noticeable gains in power and performance. It features a large-diameter, mandrel-bent, dyno-tuned intake tube, an oversized conical high-performance aFe air filter, a heat shield, and a one-piece sealed housing with a built-in sight window for hassle-free filter inspection.
The one-piece airbox and heat shield of the aFe® Momentum® HD Stage 2 Cold Air Intake System are constructed from rugged 16-gauge powder-coated steel, providing both durability and strength to withstand the toughest conditions. The steel construction ensures that the airbox and heat shield can endure high temperatures and harsh environments, such as off-road adventures, construction sites, and extreme weather conditions. As the system allows the engine to suck in air more effectively, the intake noise itself can intensify, giving the engine a throatier, more robust growl when you push the accelerator.
aFe® - Momentum® HD Stage 2 Cold Air Intake System
Notes: This product is NOT legal for installation on vehicles required to meet CARB standards and/or registered in California and other states following CARB standards, including NY and ME.
Installation is easy. The Momentum® Intake System is proudly made in the USA and has been computer-designed with your specific application in mind. Thus, it can be installed in place of the factory airbox in 30-60 minutes using simple hand tools. No drilling, cutting or fabrication required. Premium hardware, like stainless-steel clamps and a silicone coupler, is included in the box.
Learn more about aFe by following the link below:
https://www.carid.com/afe-power/
carid
carid
Supporting Vendor
Cranbury, NJ
Ready to boost your Tahoe's performance?
Don’t wait! Take advantage of the free shipping today and experience the difference that aFe® can make!
sequoia
