Upgraded to 20 inch factory rims- how to reset pressure monitor
LuSe4
Bleen Member
Michigan
I need to do this as well. But I thought you had to let all the air of the tires. Is that true or just let a little out and then start putting more air in and it should read it?
You start letting air out until the horn honks. Could be 2 pounds, could be 15 pounds. When you are done, then you go back and add air to each of them to bring them back to correct psi.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Until the Horn Honks. What i do is Register all the Sensors, then after i get the confirmation Horn. Ill go And Adjust my Pressures Accordingly.
John182223
