Pivot
- Joined
- Jul 2, 2017
- Posts
- 197
- Reaction score
- 134
Hi, all. Just figured I'd share. So I was hooking up my Uniden V3 radar detector this weekend, and discovered that those little round all-purpose 12v switches you can buy anywhere fit perfectly in the 12 outlet once you remove the actual recepticle behind it. I usually hide switches in a row someplace super low key, but I couldn't pass this one up. It fits right under the little flap.
I did dremel a couple mm into the top of the surround where the switch sits, just to recess it a bit but you really don't need that. Small bead of super glue around the edge held it in place. I didn't put the bead on the back side because I didn't want to lock up the little tabs that click the housing into place.
Also, stole power from the now-former 12v recepticle wires. Already a switched circuit and right there so it's super clean. Fused appropriately and pow.
Just thought the switch location thing was worth sharing. Cheers.
Sent from my Pixel using Tapatalk
