Vapor Canister leaks gas.
swampslider
Central Florida
I noticed a wet spot under the left front end of my 96 Yukon. It was coming from the top center nozzle of the vapor canister. It has a constant drip. I loosened the gas cap, it was under pressure, and it stopped leaking. I swapped gas caps but it still leaks. Any ideas on how to stop the leak. Thanks in advance for any and all responses.
Donnie Yukonie
Yates Caretaker
Can you post pics of where its actually leaking? Is it the relief valve or the actual body?
Roux
