I just looked at it lol. I noticed the idle is a little rougher in park. But I am trying to rule out worn spark plugs for that case. How bad should vibration feel on a worn motor mount? I know I should do the pop the hood and see how bad the motor jerks test.How did you inspect the trans and motor mounts? They can LOOK fine but could be separated and you will not see it till you try to lift the trans/transaxle and see if separates. If any of the mounts are compressed/collapsed enough, the metal can hit and cause a feeling of a vibration.
