Vibrating after Leveling Kit Install
cjp24
Alabama
Puzzling question here, a while back (like two years) I installed a leveling kit on my 07 Tahoe LT RWD (just the spacers that go under the shocks). I noticed that over the past two years it sounds like something is vibrating/shaking when braking from about 35-25 mph and maybe getting worse. Only at those speeds. If you're going 80, it brakes normally until 35ish and will then make the noise till about 25ish. It brakes fine during that speed as well but sounds pretty bad. It doesn't necessarily feel like vibration. Just sounds like it. I feel like I remember it doing it right after install and assumed it was needing alignment/brake work/etc. Well it has been aligned, tires replaced, new brake calipers, rotors, and pads in the past 6 months and still have the sound. Any ideas? Performance is completely fine except for the noise while braking from 35-25mph.
petethepug
Michael
SoCal
Any changes to rims or tire size when levelled? What size rims?
It could be as simple as brake dust accumulation on the rotors / warped rotors that plagues this generation of trucks. After all the brake part replacement did things get any better?
Have you done any maint to the rear brakes?
KidWgn
Certified Kid Hauler
St. Louis, MO
I just went through all of this.
Rear control arm bushings solved it for me.
Also, make sure your thrust angle is less than 1-degree.
Steeveyukk
